2001 s40 code P0015 and skipping
Old Mar 3, 2013 | 06:11 PM
tamark69's Avatar
Default 2001 s40 code P0015 and skipping
I got a 2001 S40 and im getting code P0015 and P 0302 and its skipping under load. At idle its fine. I have checked the cvvt valve and when it starts to skip the cvvt valve dosent seem to open, when I jump it and run 12 volts to it it opens and smooths out. Has anyone else have this problem. I know I need to do an engine oil flush and drop the oil pan. also I checked the coil for contiunity and I have contiunty when its unplugged.
Old Mar 3, 2013 | 06:43 PM
Hudini's Avatar
Oil flush may work but so far I haven't heard any success stories. Let us know if it works for you. And why are you going to drop the oil pan? Nothing about a flush would require you to drop the pan. Just drain it, add fresh oil and filter.
If it were me, I'd fix the solenoid first, then deal with the miss. The car shouldn't miss due to the CVVT. The whole reason for the CVVT is to have both low rpm and high rpm power due to shifting the cam advance. The malfunctioning CVVT solenoid may just have exposed a weak coil or bad plug or wire but not actually caused it. My guess.
Old Mar 4, 2013 | 04:17 AM
tamark69's Avatar
Is there a was to test the solenoid to see if its bad or maybe a bad ECM or broken wire
Old Mar 4, 2013 | 07:48 AM
Hudini's Avatar
Key off, no continuity between Pin 1 (left) and Pin 2 (right). Pin 1 is power supply. Pin 2 is ECM signal cable to Pin 62 on the ECM.
VIDA says: "Try a new camshaft reset valve if no fault is found during the above fault-tracing."
There are 16 actual camshaft reset valve trouble codes specific to this Volvo. You need Volvo specific hardware and software to see whats up. This is why people just end up replacing the solenoid as testing is more expensive.
Old Mar 5, 2013 | 04:17 AM
tamark69's Avatar
Well I replaced the cvvt valve and it did not fix the problem. I ran some engine flush in the oil and changed the oil, I also checked the timing marks and they are good. I'm starting to lean towards a bad fuel injector. I may just send it into the shop. Thanks for the help
Old Mar 5, 2013 | 07:07 AM
Hudini's Avatar
You probably have two issues. Did your P0015 code return? If not, and you still have a miss, then I think you had two separate issues. With the solenoid fixed I'd give it a tune up. 4 Plugs, 2 coils, 2 wires.
The fuel injectors are very robust. Please don't replace one without testing. They can be removed and bench cleaned if you are determined it's an injector. Most of the time a miss is ignition related. Usually a bad coil.
Old Mar 6, 2013 | 04:24 AM
tamark69's Avatar
I replaced that plugs and 1 coil, still skips so I moved the coil to the other plugs and still skips, so then I moved the wires and still skips on # 2 cyl. The skip never moved it stayed at # 2. I also did a compression test and I have 160 across all cylinders. I'm at a loss.
Old Mar 6, 2013 | 05:31 AM
Hudini's Avatar
Replace it all. 4 Plugs, both coils, both wires. When dealing with a miss under load I did the same thing you did. Ohmmed the coils, checked the wires, replaced all the plugs. Still had a miss. Then I replaced one coil and started moving the other around. When that did not work I swapped coils again and still had a miss. Totally frustrated I bought a 2nd new coil and new plug wires and my miss went away. I hate throwing money at a problem so this was very annoying. I found that Autozone had coils for a reasonable price, like $44 last time I replaced them. You can find a wire set online for less than local IIRC.
Old Mar 8, 2013 | 08:07 PM
tamark69's Avatar
Well I replaced both coils and the plug wires and all is good now. Thanks for all the help
Armenian
Dec 16, 2017 11:16 AM
1998xc70
2001-2013 model year XC70
Feb 13, 2013 08:00 PM
bsobo
Dec 7, 2010 03:42 PM
99S70GLT
Jul 19, 2009 10:24 PM
costa993
Feb 14, 2009 07:35 AM
