2003 S40 2.0 Non Turbo Engine vibration
I've read many comments regards noticable engine vibration experienced on the S40 models. I've replaced all 4 of my engine mounts, fly wheel and clutch. This did not fix the problem. In 4th gear you can actually feel the vibration on the gear shift as well. As someone said you can feel this vibration through the body of the can. My cars vibration is notisable from 1,000 rpm up to 2,500 rpm. 2,000 rpm is normally the revs when driving in town.
This is driving me nuts! The replacement top engine mounting is more solid than the origional. Origional mounting were larger. Did anyone found a solution for this problem yet? |
