2005 S40 ABS light after front bearings replaced
I just had the front bearings replaced at 115k miles as the driver side was really bad. When driving away the ABS light came on and I am trying to decide whether to take it back to the same small shop or go to another shop that I know is good. During the process the manager and I were cordial but there were some misunderstandings and lack of communication and delays on their part so I would rather not engage them again if I can avoid it.
Does anyone know if it is typical to get some dirt or other obstruction that could cause abs sensor failure when working in that area? The shop claims the bearings were bad for so long that some mud got on/in it. I've done some research and it is not too difficult of a job to clean or replace the sensor.
So the dilemma is should let this shop have another whack at the car or just take it somewhere else that I know is competent? I don't mind paying a little more but I would rather not to that shop and my confidence that they will make it right and not charge is low. You would think they would test drive the car and not hand it back that way.
As an aside, the rear bearings were replaced at 54.5k miles at the dealer on my dime.
Thanks for any advice or assistance.
That is a good question. I had to do all this by phone so I went with the middle of the three options of bearings he gave me. The top choice was so expensive like twice as much as the dealer wants. I will find out tomorrow morning what he really used. Family members have been doing the drop offs and pick ups
Does the brand have any "bearing" on the situation regarding the ABS light.
Thanks for the reply!
In view of above I would suggest you go back to same place.
It is highly likely that the code is related to the work done. Not sure about the 2005 but on the older vintage you might need to take the entire spindle out to use a machine press to get the bearing out. To do so you would need to unplug the abs sensor from the spindle to remove from the car. It may simply be a case of not having re-plugged the abs sensor cable up behind the wheel well cover or it might be that they damaged the abs reluctor ring on the hub when they removed/re-installed the hub.
The country bumpkin could have taken care of all of this and won a new customer. Both of theses service places charged more for parts than what the can be bought from the Volvo dealer which I am not sure how to deal with. I would done the sensosr myself with the cheap ford ones if I had known the chain place would have the car most of Saturday too.
Thanks for all the replies. Now I just have to get the front strut noises resolved for which I have an appointment at an independent shop for next Tuesday. Thanks for all the replies.
