Ac fuse blow again
These are general electrical terms. A short to ground is another way of saying that the positive 12 volt wire is rubbing against the steel body, creating a short circuit to the grounded car body. That condition will pop a fuse.
The other is the clutch coil on the compressor. They can go bad and draw a very high current, drawing enough power to pop a fuse. They can also become internally short circuited.
