| geworthsr |
Dec 3, 2020 08:07 AM |
2005 S40 question reply
My car had a couple of things going on. The drivers side rear carpet was soaked and the headliner was failing and in need of replacement. I’ve had sunroof drain clogs in the past and was relatively confident the leak was coming from that system. I pulled the seats and carpet (along with the center console, which was rather easy). With all of that gone the headliner came out of the passenger side front door with ease. With all of that gone I was able to soak the car slowly from the bottom up and look for leaks. I apologize if this get wordy, but here goes. The sunroof drains run from all four corners of the internal gutter. If all four drains were capped the gutter would simply fill and spill over into the headliner. In my case I found water coming through my sunroof at the point in the rear edge where the gasket comes together. The gasket must have shrank slightly over time creating a gap of about 3/32”. When I had finally worked my way up to the sunroof and from each low corner to the top center and let the hose flood over the entire roof, water started to drip into the gutter at a decent rate. Up to that point no water had made its way to the drivers side floor, which was a bit of a letdown. I was hoping to see a flood from somewhere. Anyway, my car parks on a spot that is slightly angled enough to send the water to the rear drivers side drain hose, and it was clogged. I pulled each drain line from the gutter and blew through them to make sure they were clear. I masked off the sunroof gasket and used silicone to fill that gap. The front divers side drain hose also ended up have a problem that might have allowed water in if the car was setting perfectly level. When I blew the hose I could hear air rushing out of the hose at the connection down by the dash. I really couldn’t get in there to see the problem, but the hose was off fitting that goes through the firewall. I reinserted the hose into the fitting with silicone to seal and hold it. All is back together and dry .... so far anyway.
Let me get back to my question if I may. Under the passenger seat is a large black electrical connection with one small spring loaded bolt holding it together. If you look under the seat it’s easy to see. Besides that there is a smaller white electrical socket connector coming from the seat that on my car has no wire coming up to it. If you look under your seat can you see if it’s used or left open. Maybe it has a use for a feature on a more loaded model.
