2007 S40 Center Console Install
It's the outer cosmetic aluminum trim bezel that wraps the control console...from the radio on down to the gear shift. I've got some scratches and a small dent in the old one. I popped out the trim piece around the radio display but couldn't figure out how to slide the display out. Thanks for your time.
Perfect, thank you Matt. You won't happen to also have the cigarette lighter assembly/electrical socket panel removal instuctions too please? It's referenced in the final step of the instructions you posted. Looks like I'll have to remove that panel as well in order to get to the two lower screws on the center console bezel. Thanks again - really appreciate it.
