2008 S40 Trunk Malfunction
Hey guys, I'm a 2008 S40 owner. These days I encountered a trunk malfunction: it won't open anymore. Here I'm gonna share all I learned during these days.
So, if you encountered a trunk malfunction, please follow this checklist: 1. Is the trunk's button switch broken? =If so, buy a button switch from Volvo retailers and replace it. Use screw drivers to undo the button column over the number plate and then replace it. Here is exactly an example of solving this kind of trunk malfunction: 2. Is the trunk's wiring hardness broken? Because S40's trunk wiring hardness would bends 180 degrees when you close the trunk, after a few years it would be broken. =If so, consult your owner's manual and check your car if it's U.S. model or not. If it's U.S. model, it would be equipped with an emergency latch inside the trunk lid, you will be able to open the trunk temporarily by using this way, and then proceed to replace the wiring hardness. Here is an example: 3. Fuse malfunction caused the trunk won't open =If so, Consult your owner's manual, and the fuse compartment is located in front of the right front seat. Follow the manual's guide to unlock the compartment and check the fuse for Trunk (which is No. 77 item in the compartment). If the fuse is blown, congratulations this is the easiest problem that can cause the trunk malfunction, you can buy a new fuse and replace the blown one. While actually I don't think this would be possible. Because the circuits for trunk related electrics won't really be overloaded... =If not, then you don't have any other item to turn to. Why? Because if your beloved S40 is not a U.S. model car, and your trunk cannot be opened, you will have no solutions to open it, not to mention to fix the malfunction. For many other cars, they all have manual ways to open the trunk if the electric one is broken. But here in Volvo S40, wow, the designer rely everything of trunk release switch on the electrics, and the electrics are so unreliable to withstand the metal fatigue! If you are in the same situation as me, I would say, the mechanics in Volvo distributors have told me that in this case the only way out will be cutting and breaking the whole trunk lid and trunk lock from inside and then replace them all. I won't do something like that, it's pretty heartbreaking to do so. I will leave it there. So, hope you guys won't encounter the same thing, and replace your trunk's wiring hardness on a regular basis before it finally went down. And also, try to install an emergency latch if your S40 is not U.S. model. Thanks for reading and hope everything goes fine with you. |
Originally Posted by solarwind
(Post 473464)
So, if you encountered a trunk malfunction, please follow this checklist: 1. Is the trunk's button switch broken? =If so, buy a button switch from Volvo retailers and replace it. Use screw drivers to undo the button column over the number plate and then replace it. Here is exactly an example of solving this kind of trunk malfunction: https://www.youtube.com/watch?v=josQ...&index=8&t=27s =If not, proceed to the next item 2. Is the trunk's wiring hardness broken? Because S40's trunk wiring hardness would bends 180 degrees when you close the trunk, after a few years it would be broken. =If so, consult your owner's manual and check your car if it's U.S. model or not. If it's U.S. model, it would be equipped with an emergency latch inside the trunk lid, you will be able to open the trunk temporarily by using this way, and then proceed to replace the wiring hardness. Here is an example: https://www.youtube.com/watch?v=8VmO...&index=20&t=0s =If not, proceed to the next item 3. Fuse malfunction caused the trunk won't open =If so, Consult your owner's manual, and the fuse compartment is located in front of the right front seat. Follow the manual's guide to unlock the compartment and check the fuse for Trunk (which is No. 77 item in the compartment). If the fuse is blown, congratulations this is the easiest problem that can cause the trunk malfunction, you can buy a new fuse and replace the blown one. While actually I don't think this would be possible. Because the circuits for trunk related electrics won't really be overloaded... =If not, then you don't have any other item to turn to. Why? Because if your beloved S40 is not a U.S. model car, and your trunk cannot be opened, you will have no solutions to open it, not to mention to fix the malfunction. For many other cars, they all have manual ways to open the trunk if the electric one is broken. But here in Volvo S40, wow, the designer rely everything of trunk release switch on the electrics, and the electrics are so unreliable to withstand the metal fatigue! If you are in the same situation as me, I would say, the mechanics in Volvo distributors have told me that in this case the only way out will be cutting and breaking the whole trunk lid and trunk lock from inside and then replace them all. I won't do something like that, it's pretty heartbreaking to do so. I will leave it there. So, hope you guys won't encounter the same thing, and replace your trunk's wiring hardness on a regular basis before it finally went down. And also, try to install an emergency latch if your S40 is not U.S. model. Thanks for reading and hope everything goes fine with you. You say to use the key to release the trunk? Just where does the key go in? I've had my car for about 8 months and had a wire in the harness broken - fixed it and it worked for a short time.. but now it's not working again.... Unfortunately, there is No Pull Cord/ Emergency Release Cord. I had to climb in the trunk and unbolt the lock to get the trunk open.. but am not quite sure what the problem is now? So I got a Bungy Cord holding the trunk closed for now. I have a 2009 S-40. the Specs for Fuse #77 say: 77 12-volt socket in cargo area; auxiliary equipment control module (AEM) 15A __________________________________________________ _________________________ Manufacturer: Volvo Geely Sweden Volvo Geely Sweden Brand: Volvo Model: S40 Year: 2009 Engine: 2.4L In-Line B5244S4 Trim 718-2.4i Engine 1617-5 Cyl 2.4 L GAS Body NumDoors 4 BodyType Sedan YV1MS382692459404 General Information MFR Model CodeS40 2.4I A Body Type 4dr Car Pass Doors 4 Alternative Name Alternative Body 4dr Car Drivetrain Front Wheel Drive Original Pricing MSRP$28,550.00 Invoice$24,158.00 Destination Charge $795.00 Engine & Powertrain Type5 Cylinder Engine Displacement L/CI/ Fuel Type Gasoline Fuel Horsepower 168.0 @ 6000 Fuel Economy20.0 City / 31.0 Highway MPG Fuel Capacity15.0 gal Net Torque170.0 @ 4400 Tech Specs Manufactured BySweden Passenger Cars Suspension Type - FrontMacPherson Strut Suspension Type - RearMulti-Link Front Tire SizeP205/50R17, P205/55R16 Rear Tire SizeP205/50R17, P205/55R16 Brake ABS System4-wheel Wheelbase103.9 in 103.9 min 103.9 max __________________________________________________ ______________ Fuses list with amperage Note: Fuses 1-18 are relays/circuit breakers and should only be replaced by an specialized technician. Number Description Amperage 1 Coolant fan (radiator) 50A 2 Power steering 80A 3 Feed to passenger compartment fuse box 60A 4 Feed to passenger compartment fuse box 60A 5 Element; climate unit 80A 6 Not in use 7 ABS pump 30A 8 ABS valves 20A 9 Engine control module (ECM) 30A 10 Climate system blower 40A 11 Headlight washers 20A 12 Feed to heated rear window 30A 13 Starter motor relay 30A 14 Trailer connector 40A 15 Not in use 16 Feed to audio system 30A 17 Windshield wipers 30A 18 Feed to passenger compartment fuse box 40A 19 Not in use 20 Horn 15A 21 Not in use 22 Not in use 23 Engine control module (ECM)/transmission control module (TCM) 10A 24 Not in use 25 Not in use 26 Ignition switch 15A 27 A/C compressor; water shut-off valve 10A 28 Not in use 29 Front fog lights (option) 15A 30 Engine control module (ECM) 3A 31 Generator voltage regulator 10A 32 Fuel injectors 10A 33 Heated oxygen sensor; vacuum pump 20A 34 Ignition coils; engine control module; climate unit pressure sensor 10A 35 Engine sensor valves; A/C relay; relay coil water shut-off valve 15A 36 Engine control module (ECM); throttle sensor 10A 37 Not in use 38 Not in use 39 Not in use 40 Not in use 41 Not in use 42 Not in use 43 Audio system; Volvo Navigation system (option); 15A 44 Supplemental Restrain System (SRS) 10A 45 12-volt socket in rear seat 15A 46 Lighting – glove compartment; instrument panel; and footwells 5A 47 Interior lighting 5A 48 Tailgate wiper/washers; Windshield washers 15A 49 Supplemental Restrain System (SRS); Occupant Weight Sensor (OWS) 10A 50 Not in use 51 Park assist (until 2007); AWD; Bi-Xenon headlights (2007 only); fuel filter relay (from 2008) 10A 52 Transmission control module (TCM); 5A 53 ABS; power steering; Bi-Xenon headlights (up to 2006) 10A 54 Engine control module and turbo; ECM (until 2007); Park assist (from 2008); Bi-Xenon headlights (from 2008) 10A 55 Not in use 56 Alarm siren control module; Volvo Navigation System Remote Control (2008 on) 10A 57 On-board diagnostic socket; brake light switch; 15A 58 Right high beam; auxiliary lights relay; 7.5A 59 Left high beam 7.5A 60 Heated driver’s seat (option) 15A 61 Heated passenger’s seat (option) 15A 62 Moonroof (option) 20A 63 Power window and door lock – rear passenger’s side door 20A 64 Audio system; Volvo Navigation system (option); 5A 65 Audio system; 5A 66 Audio system control module (ICM); climate system; 10A 67 Not in use 68 Cruise control 5A 69 Climate system; rain sensor (option) 5A 70 Not in use 71 Not in use 72 Not in use 73 Moonroof; front ceiling lighting; auto-dim mirror; seat belt reminder 5A 74 Fuel pump relay 15A 75 Not in use 76 Not in use 77 12-volt socket in cargo area; auxiliary equipment control module (AEM) 15A 78 Not in use 79 Back-up lights 5A 80 Not in use 81 Power window and door lock – rear driver’s side door 20A 82 Power window and door lock – front passenger’s side door 25A 83 Power window and door lock – front driver’s side door 25A 84 Power passenger’s seat 25A 85 Power driver’s seat 25A 86 Interior lighting relay; cargo compartment light; power seats __________________________________________________ ______________________ ENGINE COMPARTMENT FUSES № A Protected Component 1 50 Cooling Fan Control Modul 2 80 Electrical Power Steering Module (EPS) 3 60 Сomfort Relay (R18), Central Electronic Module (CEM), Fuse №: 45, 48, 49, 60, 61, 62, 63, 68, 69, 80 (2008-2013), 84, 85 4 60 High Beam Relay, Reverse Interlock Solenoid (Manual Transmission - 2004), Central Electronic Module (CEM), Fuse №: 55, 58, 59, 74, 77 5 80 PTC Element 6 60 Diesel (2004-2005): Glow Plug Control Module 60 Diesel 4-Cyl.: Glow Plug 70 Diesel 5-Cyl.: Glow Plug Control Module 7 30 2006-2012: Brake Control Module (BCM) (Pump) 40 2013: Brake Control Module (BCM) (Pump) 8 20 Brake Control Module (BCM) (Valves) 9 30 Main Relay (Engine Management System), Fuse №: 32, 33, 34, 35, 36 10 40 Fan Control Module 11 20 C30, S40, V50: Headlight Washer Motor Relay, High Pressure Headlight Washer Pump 20 С70: Convertible Roof Module (CRM), Headlight Washer Motor Relay, High Pressure Headlight Washer Pump 12 30 Heated Rear Window Relay, Heated Rear Window 13 30 Starter Motor 14 40 Trailer Module (TRM), 13-pin Outlet (Tow Hitch Cable Harnes) 15 30 С70: Convertible Roof Module (CRM) 16 30 C30, S40, V50: Infotainment Relay, Audio Module (AUD), Fuse №: 22, 43, 64, 65, 66, 67 40 С70: Infotainment Relay, Audio Module (AUD), Fuse №: 22, 43, 64, 65, 66, 67 17 30 Wiper Motor Module (WMM) 18 40 Reversing Light Relay, Interior Lighting Relay, Central Electronic Module (CEM), Fuse №: 46, 47, 56, 57, 79, 81, 82, 83, 86 19 - - 20 15 Horn Relay, Horn 1 & 2 21 20 Combustion Preheater Module (CPM) 22 15 2005: Subwoofer Module (SUB) 25 2006-2011: Subwoofer Module (SUB) 20 2011-2013: Subwoofer Module (SUB) 25 С70: Subwoofer Module (SUB) 23 10 Transmission Control Module (TCM), Engine Control Module (ECM (5-Cyl.)) 15 6-speed PowerShift - MPS6 (2009-2013): Transmission Control Module (TCM) 24 20 Diesel: PTC-Resistor - Crankcase Ventilation (5-Cyl. - 2006-2013), Electrically Heated Fuel Filter 25 10 2010-: Secondary Battery (1.6l Diesel), Central Electronic Module (CEM (1.6l Diesel)) 26 15 Starter Motor Relay, Start Control Module (SCU), Engine Control Module (2004-2005), Central Electronic Module (CEM), Fuse №: 44, 51, 52, 53, 54, 73 and Fuse in Holder 27 10 Electromagnetic Clutch (Climate Control System) 28 10 2005: Climate Control Module (CCM), Multimedia Module (MMM) 29 15 Front Fog Lights Relay, Front Left/Right Fog Light 30 3 Diesel 4-Cyl.: Engine control module (ECM (2.0l Diesel, 1.6l Petrol)) 10 2010-2013: Coolant Pump (1.6l Diesel) 31 10 2004-2005 (Diesel): Alternator (Voltage Regulator) 10 2006-2013 (4-Cyl.): Alternator (Voltage Regulator) 32 10 Petrol (2004): Injectors 10 2005: Fuel Filter Pre-Heater Relay, Front Heated Oxygen Sensor, Injectors (Petrol), Valve Coolant 10 2006-2013: Mass Airflow Sensor (MAF) (5-Cyl. Diesel), Regulator Motor (Turbo), Front Heated Oxygen Sensor (4-Cyl.), Rear Heated Oxygen Sensor (4-Cyl.), Injection Valves (5-Cyl.), Coolant Valve (4-Cyl. 2.0L Diesel), Rear Heated Oxygen Sensor (4-Cyl. 1.6L Diesel (2007)), Glow Plug System Relay (2008-2013), Intercooler Bypass Valve (1.6l Diesel), Fuel Flow Control Valve (2011) 33 20 2004: Fuel Filter Pre-Heater Relay (Diesel), Vacuum Pump, Front/Rear Heated Oxygen Sensor 20 2005: Vacuum Pump, Front/Rear/Middle Heated Oxygen Sensor 20 2006-2013: Vacuum Pump Switch, Engine Control Module (ECM (5-Cyl. Diesel)), Vacuum Pump (5-Cyl.), Front Heated Oxygen Sensor (5-Cyl.), Rear Heated Oxygen Sensor (5-Cyl.), Center Heated Oxygen Sensor (5-Cyl. without Turbo), PTC-Resistor - Crankcase Ventilation (4-Cyl. 2.0L), Heated Fuel Filter (Diesel), Vacuum Pump Relay (2010-2013) 34 10 2004: Engine Control Module (ECM), Fuel Volume Control Valve (Diesel), Fuel Pressure Control Valve (Diesel), Spark Plug and Ignition Coil 10 2005: Engine Control Module (ECM - 5-Cyl.), Injection Valves, Injector, Fuel Volume Control Valve (Diesel), Spark Plug and Ignition Coil, Transformer - Ignition Coils, PTC Resistor - Oil Trap 10 2006-2013: EGR Valve, Fuel Pressure Control Valve (2006-2007), Spark Plug and Ignition Coil, EGR Cooling Bypass Valve (2006-2008), Fuel Pressure Bypass Valve (Man), Injection Valves (1.6l), Fuel Volume Control Valve (4-Cyl. 2.0l Diesel), Fuel Flow Control Valve (4-Cyl. 1.6l Diesel), Pressure Monitor (Climate Control System (5-Cyl.)), Ignition Coils (Transformer (1.6l)), Glow Plug Control Module (GCU (5-Cyl. Diesel - 2008-)), EGR Valve (5-Cyl. Diesel - 2008-2013), Starter Motor Relay (1.6l Diesel - 2010-2013), Battery Relay (1.6l Diesel - 2010-2013), Secondary Battery Relay (1.6l Diesel - 2010-2013), Coolant Pump Relay (1.6l Diesel - 2010-2013), Engine Control Module (1.6l Diesel - 2010-2013), Front Heated Oxygen Sensor (4-Cyl. - 2011-2013) 35 10 2004 (E.E.): Climate Control System Relay, Fuel Leakage Control Pump, Mass Airflow Sensor (MAF), EVAP Valve, Intake Variable Valve Timing Solenoid, Turbocharger Control Valve, Variable Valve Timing Outlet Solenoid, Bypass Valve (Diesel), Variable Turbo Geometry Solenoid (Diesel), Expansion Tank Cut-off Valve (Diesel), Intake Control Valve (Diesel), PTC Resistor - Oil Trap 15 2004 (L.E.): Climate Control System Relay, Fuel Leakage Control Pump, Mass Airflow Sensor (MAF), EVAP Valve, Intake Variable Valve Timing Solenoid, Turbocharger Control Valve, Variable Valve Timing Outlet Solenoid, Bypass Valve (Diesel), Variable Turbo Geometry Solenoid (Diesel), Expansion Tank Cut-off Valve (Diesel), Intake Control Valve (Diesel), PTC Resistor - Oil Trap 15 2005: Climate Control System Relay, Fuel Leakage Control Pump, Engine EGR, Mass Airflow Sensor (MAF), Water Detection Sensor, Injection Valves, EVAP Valve, Intake Variable Valve Timing Solenoid, Turbocharger Control Valve, Power Steering Pressure Switch, Variable Valve Timing Outlet Solenoid, Bypass Valve (Diesel), Variable Turbo Geometry Solenoid (Diesel), Intake Valve Mixing Air/Fuel Control Valve (Diesel), PTC-Resistor Air Preheating 15 2006-2007: Climate Control System Relay, Fuel Leakage Control Pump, Engine EGR (1.6l Diesel - 2006-2011), Mass Airflow Sensor (MAF), Water Detection Sensor, Injection Valves, EVAP Valve, Intake Variable Valve Timing Solenoid, Turbocharger Control Valve, Power Steering Pressure Monitor, Variable Valve Timing Outlet Solenoid, Control Valve Inlet, Variable Turbo Geometry Solenoid (4-Cyl. Diesel), Valve Mixing Air/Fuel (5-Cyl. 1.8l & 2.0l), Engine Control Module (5-Cyl. Diesel), Crankcase Ventilation PTC-Resistor (5-Cyl. Petrol) 15 2008-2013: Climate Control System Relay, Engine Control Module (5-Cyl. Diesel), Fuel Leakage Control Pump (5-Cyl.), EGR Motor (1.6l Diesel, 1.8l Petrol), Mass Air Flow Sensor (MAF (5-Cyl. Petrol, 4-Cyl. Diesel)), Water Detection Sensor (4-Cyl. Diesel), Injection Valves (1.8l), EVAP Valve (Petrol), Intake Variable Valve Timing Solenoid (5-Cyl. Petrol), Turbocharger Control Valve (2.5l Turbo), Variable Intake Manifold Vacuum Valve (1.8l), Power Steering Pressure Switch (1.6l), Fuel Volume Control Valve (2.0l Diesel - 2008-2010), Exhaust Variable Valve Timing Solenoid (2.5l Turbo), Variable Turbo Geometry Solenoid (4-Cyl. Diesel), Air/Fuel Mixing Valve (1.8l), Intake Control Valve (2.0l Diesel), PTC-resistor - Crankcase Ventilation (5-Cyl. Petrol), EGR Cooling Bypass Valve (2011-2013) 36 10 Engine Control Module (ECM), Front Heated Oxygen Sensor (5-Cyl. Diesel - 2006-2013), Accelerator Pedal Sensor 20 Fuse in Holder: Front Left/Right Auxiliary Lights Relay R1 2010-2013: Coolant Pump R2 Horn R3 2010-2013: Vacuum Pump R4 Front Fog Light R5 Fuel Filter Preheate R6 2010-2013: Autostart R7 2010-2013: Secondary Battery R8 - R9 Headlight Washer Motor R10 Heated Rear Window R11 Climate Control System R12 Diesel (2008-2013): Glow Plug System R13 Starter Motor R14 Main (Engine Management System) INSIDE FUSE COMPARTMENT __________________________________________________ _________________________ I hope you'll still follow this post and be able to reply. Thank You for the Helpful Info! |
| All times are GMT -5. The time now is 04:56 AM. |
