-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   ABS Control Module, speedometer, etc. (https://volvoforums.com/forum/volvo-s40-11/abs-control-module-speedometer-etc-20993/)
darimik Jun 24, 2008 12:21 AM
Hello,
I have a 2001 Volvo S40 1.9L Currently my speedometer does not work, as well as the odometer. My ABS and Brake lights are on. I know that the speed is reported by the ABS Control Module, therefore it explains why my speedometer does not work when my ABS light is on.
Thanks to this forum, I have learned that you can get a cheaper rebuild for your ABS module. However, I have another option, which I am not sure is going to work.
Has the ABS Control Module changed on the next Volvo S40 model? Can I take out the ABS Control Module from the 2003 Volvo S40 ? Does anyone one if those parts are the same ?
Thanks
Blessyouboys Jun 24, 2008 06:37 AM
RE: ABS Control Module, speedometer, etc.
I wouldn't necessarily jump to the conclusion the ABS Module is bad. When the ABS light comes on, it means the ABS system has detected a fault and disabled itself. You need to find out what the fault is.
Find someone who has a scanner that can read ABS codes, and get the codes read. It may be a speed sensor.
darimik Jun 24, 2008 09:15 AM
where exactly is the speed sensor located ?
Blessyouboys Jun 24, 2008 11:12 AM
I believe the Vehicle Speed Sensor is located on the transmission.
Do yourself a favor, get the ABS codes read.
darimik Jun 24, 2008 12:38 PM
Do you know if Autozone can read those ? Or would I have to go to a private shop? Its probably $80 at the dealership..
jks2 Jun 24, 2008 03:23 PM
Yes, Autozone can read the codes. I still think that it is your ABS module, but check to find out for sure.
Blessyouboys Jun 24, 2008 04:10 PM
ORIGINAL: darimik
I seriously doubt Autozone will help you. ABS Codes are Chassis codes, the generic code readers found at Autozone will only read Powertrain codes.
ORIGINAL: jks2
It may well be, and probably is. But rather than throwing parts at it, he might as well diagnose the problem first.
mncx Jun 24, 2008 08:03 PM
I haven't seen an ABS module goes on a S40 before...... And no generic code reader will not get u much help either...
