any ideas
I have a 2000 S40, and I just had the weirdest problem.
I was driving in traffic when the rpms all of a sudden went up and stayed high. I drove a little longer trying to get the idle down, by tapping the gas, etc. They just stayed high and the car accelerated to where the rpms were. I really had to use the brakes as hard as could to stop entirely. Then I put the car in neutral and the rpms went way up since it had no load. I shut off the car then noticed the temperature went to the red. I tried to start it again but it wouldn't turn over. I had no warning or check engine lights at all. I left the car for 1.5 hours, checked he fluids and coolant which were fine. Then I started the car (with no problem) then drove it all the way home (20 miles) without a problem. What could this be???????????? I don't want to drive the car when it does something this crazy. Help please?? |
RE: any ideas
Sounds like the thermostat may have gotten stuck closed temporarily. I would change that just to be safe. High temps will affect the engine performance.
RE: any ideas
Would the thermostat sticking actually cause the engine to stay at higher revs and not come down to idle??
RE: any ideas
This problem ended up being the temperature sending unit, underneath the thermostat, if this ever happens to anyone.
