-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   Blinking Check Engine light (https://volvoforums.com/forum/volvo-s40-11/blinking-check-engine-light-13325/)
nick61416 Aug 23, 2007 12:42 PM
Yeah i got this today.
So i drive to the shore and have some from on the highways going pretty fast. at this point my car is feeling fine nothing wrong with it. As i am coming home the next day my car starts driving fine. As i get out of the toll and accelerate pretty hard i guess my engine starts to sputter and rumble (not feel right at all). My check engine light starts to blink.
It feels like it could be the turbo, but what should i do about this problem?
Should i bring it to a shop and do think its something really serious.
I've been just driving it around and if i accelerate hard thats when the cehck engine light will blink. otherwise it justs satys on. I've read some other posts and i don't know if it would be the spark plugs.
Thanks for the help.
Car is 2002 volvo s40 1.9t
nandrolone Aug 24, 2007 04:57 PM
RE: Blinking Check Engine light
It sounds like the spark coils.
b5254t Aug 24, 2007 07:49 PM
Check your plugs But take a look at your fuel pressure regulator, pull the line off of it and see if there is gas in it if so that may be your culprate.
nick61416 Aug 24, 2007 11:34 PM
it wierd cause now my check engine light went off and the car seems to be driving fine. Is this normal??
b5254t Aug 25, 2007 08:30 AM
I would take it and see what codes were thrown,probrably misfire codes which could damage your catalytic convertor, best to take care of it now b4 it turns into a bigger problem.
nick61416 Aug 25, 2007 02:32 PM
ok yeah i believe the catalytic convertor went out not to long ago and that got replaced. yeah im gonna bring it to my mechanic sometime just to make sure everything is all right.
thanks
JPN Aug 25, 2007 08:41 PM
Hello Nick,
Greetings.
Make sure that your mechanics is privy to modern electronic engine control systems. If not, random replacement of sensors/components would result.
I would also consider visiting a local auto parts shop, such as AutoZone where they provide free OBD-II diagnostic service (OBD-II: On-Board Diagnostic Second generation; you can hook up a scanner/diagnostic equipment onto your car to "talk to" the on-board computer to see what's wrong). They can connect their OBD-II scanner and retrieve codes from the engine & transmission computers and can tell you what code(s) is stored, as well as a brief description of the problem.
I wish you find the problem & correct it.
JPN
phildo Mar 22, 2013 01:45 PM
yeah my friggin cars doing the same thing i went to auto zone and a full diagnose check and couldnt figure out why it was doing it does anybody know anything what it could be ... i was thinking the ignitors plugs but if i start pulling off it could be another thing ... help ... help
willfishalot Mar 22, 2013 10:24 PM
mine did the same thing when i "punched" the gas on the interstate a few months ago. the check engine light was on at the time, then started blinking. i was really nervous
got it checked out, and it was the ignition coil(s) based on the diagnosis code. got it replaced, and it runs great.
volvo dealership may do a free diagnostic.
BUT -- take it to someone who has volvo experience; not necessarily the dealership. experience IS KEY.
Genomachino Mar 26, 2013 09:01 PM
1 Attachment(s)
My 2001 S40 did the same thing... Missed under hard acceleration and the Check Engine Light blinked. I replaced plugs first and that helped, but still missed and flashed the CEL, so I replaced the Ignition Coils also. Runs better now than since I first bought it!
Coils were fairly inexpensive at Amazon.com and AutoZone - $40 each at Amazon, $50 each at AutoZone.
goo.gl/rK62j
AutoZone actually matched the Amazon price for me! Easy to change out. They just plug in to the top of 2 of the 4 spark plugs. See picture.
Good luck!
Karla Camacho Aug 8, 2019 01:08 PM
When this happened to my car, it kept coding a misfire in one of the cylinders. I followed the advise from this forum and changed the ignition coil, and she’s now running smoothly!!
