Camshaft Reset Valve - P0014 Code
Check engine light - code P0014 keeps coming on. The car also seems to burning lots of oil (no leaks). Had an oil leak fixed a couple of months ago.
From what I can gather, it's likely the cam position sensor and/or soleniod or the camshaft reset valve (CVVT). I'm thinking it's the valve as there may be some sludge as a result of the previos oil leak that could me impacting its performance. Not sure if this is related to the oil burn though. Any ideas? Thanks ----------- 2000 S40 110,000 miles |
The code P0014 has to be crossed referenced to ECM-644A camshaft reset valve. I am having same code problem.
