CEL with P0420 code
Old Sep 27, 2009 | 02:05 PM
tr_car_nut's Avatar
Default CEL with P0420 code
What's the most likely part to replace with the P0420 code from the check engine light? Is it the pre-cat ($200 eBay) or the back cat ($200+ eBay) or the O2 sensors? My CEL has now been on for over a week and January 2010 the car is due for inspection. North Carolina inspections are a little easier on smog then CA.
Old Sep 27, 2009 | 04:53 PM
Could also be a vacuum leak.
I would guess front O2 if all else is good.
Old Sep 29, 2009 | 03:10 PM
tr_car_nut's Avatar
Well this is a little odd. I changed the spark plugs this weekend and the light went off. Two of the plugs had worn down the metal tip that pokes out of the insulator almost all the way down to the insulator while the other two still had a sharp point sticking out of the insulator. The car had Volvo plugs in it and I replaced them with Bosch.
Old Sep 29, 2009 | 07:02 PM
Yes weird.
Old Sep 30, 2009 | 10:36 AM
Lyonsroar's Avatar
Originally Posted by cuuspre
I have the same idea with you. Great! Thanks for sharing.
Glad to hear you're using this: I plan to keep it much more aggressively up-to-date than has been the case in the past, but don't hesitate to let me know if you find errors or need clarifications.
whaa?
Old Sep 30, 2009 | 06:40 PM
Originally Posted by Lyonsroar
whaa?
It was spam and it is deleted and poster was banned.
Old Oct 2, 2009 | 07:02 AM
tr_car_nut's Avatar
Driving into work today (only seven miles to the office) there was a very bad rotton egg smell and it wasn't coming from me. CEL is still off but the odor was so strong. Will a bad catalytic converter give off that odor?
Old Oct 2, 2009 | 07:04 PM
Yes it can.
Old Oct 3, 2009 | 10:24 AM
Lyonsroar's Avatar
Thought so.
Old Oct 5, 2009 | 10:40 AM
tr_car_nut's Avatar
Well the CEL came back on again. Is it more likely for the front pre-cat to give off that odor or can it come from the back one as well. I'm just trying to figure which part to change first.
Old Oct 5, 2009 | 07:30 PM
I would do the front one first.
Old Oct 7, 2009 | 08:53 AM
tr_car_nut's Avatar
Is it okay to use the generic O2 sensors (the ones without the connectors) since they cost about $30 as opposed to the Volvo ones that cost $130?
Old Oct 7, 2009 | 10:42 AM
Lyonsroar's Avatar
I think you'd have to splice the wires to make it work. I've heard of people using them before though.
Old Oct 10, 2009 | 03:16 PM
Volvo's hate spliced O2 sensors.
MarkS60
Sep 8, 2016 07:07 AM
79lilred
Aug 21, 2011 06:36 PM
athelmiller
Apr 8, 2011 09:54 AM
fioramosca
Oct 7, 2010 09:14 PM
mr maraki
Sep 3, 2008 09:21 PM
