CEM removal from 2002 s40
Old 11-13-2018, 02:45 PM
Newport_j's Avatar
Default CEM removal from 2002 s40
I have a 2002 Volvo s40 with a faulty Central Electronics Module. Whatever I eventually do - repair or replace, I must remove the CEM from my car. I have a DVD disk which should tell me. It says my
files have expired(?). I cannot use it..
Is there some place online that has the diagrams for removing the CEM from my Volvo. Must I buy a new disk with unexpired files?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Old 11-14-2018, 08:41 PM
are you looking to replace the CEM or figure out why your DVD disk isn't working? Try resetting your PC's clock to something like 2000 and see if the program will read again. As to replacing the CEM, its pretty straight forward. First find your radio code and keep it handy. Next disconnect the battery. You will find the CEM as the box with two big electrical connectors under the dash by the hood release. The connectors can be a PITA to separate off so be patience and wiggle/pry but they'll come off. As I recall, I had to work at some odd angles to disconnect and remove the part. The good news is your replacement does not need to paired to the ECU so you can go with used part from a yard etc (got mine for $65)
Old 11-15-2018, 01:40 PM
Newport_j's Avatar
I will try that. Thanks for your suggestion. I never knew these would expire.
I hope this works.
Respectfully,
Newport_j
JenniferXC70
2001-2013 model year XC70
10-25-2022 10:46 PM
Alexis Covarrubias
04-21-2019 11:41 AM
Newport_j
02-21-2019 04:13 PM
rnmikes
11-08-2014 10:10 AM
cally51
06-01-2012 08:56 AM
Quick Reply: CEM removal from 2002 s40
