Crankcase ventilation needs to be replaced!
Old Apr 23, 2011 | 11:39 AM
loai's Avatar
Default Crankcase ventilation needs to be replaced!
took my car to the dealer, and they pinpointed several things that need to be checked.
1- the crankcase ventilation thing needs to be changed, i have no idea what this is!
2- brake pads need to be replaced, any brand you guys suggest!? also i want the thing that covers them to be red, is it easy to paint them? my car is a red one
3- the Bosch spark plugs installed are not suitable for my car, according to the mechanic guy, it will reduce fuel efficiency!!
4- is it normal for the engine to have a slight vibration? i could feel it while sitting in the car
many thanks guys
Old Apr 23, 2011 | 10:11 PM
AutoNaut's Avatar
Is the engine making a horrid noise at idle? It is a sign that the crank case vent needs replacing. This is a known issue on these cars and Volvo extended the warranty for this item.
Brake pads: Volvo pads are a no-brainer. I also recommend Hawk HPS for longer life and less dust.
Spark plugs: Go with the Volvo plugs. They are excellent and correct.
My car has a slight vibration but yours could be due to the plugs and/or the crank case vent.
Stan
Old Apr 24, 2011 | 05:03 AM
loai's Avatar
yep, there is a horrid noise!
just got back from the service shop, they told me it would cost around $400, and they can't do it, so i called the dealer and they also said it would cost $400.
they mechanical guy told me he could remove the sound since it's so annoying, so he pulled a hose or something and the sound stopped, but he said i should change it.
concerning the spark plugs, i found Volvo ones but not at the dealer for $50, but it said excl turbo, and mine is turbo, would that make a diff?! at the dealer they cost $90!
Old Apr 24, 2011 | 10:47 PM
AutoNaut's Avatar
I believe the turbo plugs have a longer thread.
I looked these up at MySwedishParts.com
The oil filter housing part number is 30788494 (~ $95 for the part).
Spark plugs for the T5 (turbo) part number should be 30751806 (~ $50 for the set)
Stan
Old Apr 25, 2011 | 06:41 AM
loai's Avatar
the T5 on the C30 is the same on my 2004.5 S40?
another thing, i went to replace the air filter, should i get the original volvo one or the K&N?
if i got the K&N, will it reduce fuel economy?!
majorcode
Jan 17, 2012 06:04 PM
Counselor828
Jun 30, 2010 03:32 PM
Sofar.
Jan 15, 2009 02:42 PM
850forum
Feb 25, 2007 01:51 AM
brickyardboy
Apr 19, 2006 08:59 PM
