-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   Cranks to long before it starts (https://volvoforums.com/forum/volvo-s40-11/cranks-long-before-starts-50658/)
silviamft Feb 22, 2011 12:24 PM
Hello,
I have a 2000 Volvo s40, and I am having a problem at start up. This issue is intermittent and weather does not seem to be a factor. Sometimes when I start the car it takes five to seven cranks before it starts and other time it starts right away on the first crank. I have the battery checked and replaced the spark plugs. Even had a shop hook it up to a computer and there were no problems. Any ideas or things I can do? :confused:
Thank you,
Silvia
silviamft Feb 22, 2011 12:30 PM
Heat/AC blower does not turn off
Hello,
I have a 2000 Volvo s40 and the heat/ac blower stays on high at all times. I am able to change the temperature, and where it blows (feet, front panel, etc.), but I can not turn the fan down or off. It seem that it's on the 4th setting at all times and I can turn it on the 5th, but can't turn it down or off. :mad:
Thank you,
Silvia
