Door stop driver side door
My driver side door gives a metallic crumpling sound when it is fully extended. ; it only started happening recently. I was told by a mechanic that the doorstop need replacing.
I have a 2002 Volvo s40. What is the part name and number and is it hard to replace? Again this is the driver side door. Thanks in advance. Newport_j |
Have similar Door Stop Problem 2000 S70
Yah, I didn't even know what to call the part...Is it expensive ??..
It allows the door to open half-way to keep from denting adjacent parked cars, and then fully open... Looks like a ball-joint knuckle into the door post; guessing the inside door cover needs removed....what mysteries/nightmares await ?? Replace Window Regulator/Motor while we're in there ??? Any One ??? |
Have a look in VIDA!
Do you mean #7 in this pix? http://www.volvopartswebstore.com/im.../GR-368885.jpg That would be a 30652143. |
Check with Tascaparts.com.
Heh, Tasca thinks a 30652143 is a wheel arch molding. I picked up the pic from http://www.volvopartswebstore.com/im.../GR-368885.jpg so I would guess Volvo Parts - Authentic OEM Volvo Parts direct from Volvo Parts Webstore | VolvoPartsWebstore.com would have the part. Around $46. This would be a good junker part, if they want less for it. |
Originally Posted by mf70
(Post 398297)
