Electric noise at starting till 30secs after the car's off
My fellow Volvo owners,
Just noticed some driver-side noise under the hood (like big Fluorescent tubes) once I pushed the key to my car before starting.
It starts once I push the key in (not even started the electric system or start the car). It disappears about 30 seconds after the car is turned off.
Brake fluid level is find. Oil level is fine. Battery is fine to start the car normally.
I found in "common questions" section that this may be caused by brake pump. I've located the buzz in the following pic, is it the brake pump?:
https://plus.google.com/u/0/photos/1...46725243658913
I've uploaded a youtube video on the location of the noise:
Any thoughts will be appreciated.
Hey guys, I think I found the solution:
2005 V50 T5: vacuum pump..the vac pump (..overheated..blown - JustAnswer
All I did is to press the brake paddle several times when the car is cold, then the vacuum pump works again!!
adamsrotors
Dec 2, 2014 02:30 PM
adamsrotors
Dec 2, 2014 02:19 PM
adamsrotors
Dec 1, 2013 02:47 PM
adamsrotors
Dec 1, 2013 02:46 PM
adamsrotors
Dec 1, 2013 02:45 PM
