| theequalizer |
Oct 13, 2012 07:58 AM |
Engine Fan Control; ON when ignition in OFF position
Hello enthusiasts!
I just can't get engouh of you, visiting the site once per week over the weekends got me hooked.
I have this current issue; the low rpm choking start I had described in another post, led me to do a thorough cleaning of all sensors that I could see on the engine, MAS, MAP, Oxygen, including a radiator fan sensor connected permanently to the fan motor wiring. I obtain a better result for the choking BUT after that I drove the car (normal) and when I parked and turned of the ignition, the FAN STAY ON FOREVER. Coming back home, after 24 hours, even when car is cool, if I turn ignition key off (engine not started), the radiator fan RUNS continuously, when I put the ignition ON, the radiator fan goes OFF. Otherwise, when I start the engine and run, the fan goes ON and OFF normally depending on engine temprature,as it is supposed to do.
Please do give me an answer, because I am stuck and cannot go anywhere with my car in this situation...
