Engine Misfiring
Old Jul 10, 2006 | 09:19 PM
Maulsby's Avatar
Default Engine Misfiring
Hello all, I'm hoping one of you Volvo pros will be able to help. My check engine light came on and I looked it up in the manual. It said it was an exhaust problem. I noticed when I accelerate on the highway with the A/C on the engine jerks and misfires pretty bad, it also happens when I am going up the mountains. The repair shop told me the O2 sensor, thermostat, and # 3 cylinder showed up when they ran the codes. Can any of you help. Do all or any of these problems sound familiar. I pulled the plugs and they don't look bad, also once I pulled the plugs, the car won't start at all. It won't even crank. I have a friend coming over tomorrow but any help or experience would be nice. The lights work no problem, the batter and all electrical, but it just won't crank. Thank you in advance.
A frustrated Volvo owner
Old Jul 10, 2006 | 09:38 PM
Default RE: Engine Misfiring
I would replace the Plugs and coils.
Make sure you have power to the small wire at the starter. If you do the starter is bad.
Old Jul 12, 2006 | 05:01 PM
Kimela's Avatar
Definitely replace at least (1) of the (2) ignition coils. They're about $50 each. My 2002 S40 was doing the same thing after I'd had it tuned up... what I didn't know was removing or replacing the plugs can cause the coils to go bad (so the guy at volvo said). He recommended only replacing one at a time. If it doesn't fix it, first try switching the coils before you buy a 2nd coil.
Unfortunately, I had to buy 2 new coils, but my car runs like new again & gets better gas mileage now after the tune up & new coils than it did when I bought it. (31 mpg) Good luck!!!
Old Jul 19, 2006 | 05:41 PM
ZIGZAG's Avatar
ah ha coils again, my dealer here tells me he has never heard of this problem but i have a misfire when idle. I have told him it is the coils and he denies it. maybe he should talk to some of the people on this forum.
THIS SHOULD BE A RECALL. BAND TOGETHER S40 OWNERS AND GET VOLVO TO DO SOMETHING ABOUT THIS.
Old Oct 5, 2006 | 06:50 PM
airapetov's Avatar
ORIGINAL: Maulsby
Hello,
I have the same problem. Did you fix yours? If so what was the reason?
Thanks,
Roman
Old Oct 10, 2006 | 12:35 AM
skatermattc2's Avatar
Yup! Sputtering durring hard acceleration. Volvo plugs from the dealer and new coils did the trick for me.
Old Oct 21, 2006 | 02:58 AM
airapetov's Avatar
ORIGINAL: skatermattc2
Thanks skatermattc2,
I replaced ignition coils. It fixed ignition, misfiring and turbo hesitation.
Old Oct 21, 2006 | 09:15 PM
ariston18's Avatar
Hi everyone.
I too, have the same problem when I floor my accelerator. The engine misfires and sputters. The check engine light also flashes whenever this happens. During normal acceleration everything's good.
If its the same problem everyone's talking about, will changing both the spark plugs and ignition coils work? Should I try out the coils first? Also, I'm not too familiar with the s40 engine layout. Should there either be individual ignition coils for each of the 4 cylinders, or all the coils mounted on 1 pack? How cone there are only 2 ignition coils for the S40?
Old Oct 21, 2006 | 09:46 PM
One coil feeds 2 cylinders.
To be safe I would replace both the coils and the plugs.
Old Oct 22, 2006 | 03:07 AM
ariston18's Avatar
Is it something that can be DIY? I look at the engine and I cant even locate spark plugs. Never had a turbo car before so forgive me. Maybe I should buy the repair manual online.
Also, can anybody recommend volvo performance ignition coils and spark plugs? Whats a good website?
Old Oct 28, 2006 | 07:57 PM
Remove the black cover on the top of the engine to gain access to the coils.
Old Oct 30, 2006 | 03:26 AM
ariston18's Avatar
I've bought the vadis repair manual from someone on ebay whose link u sent to someone some time ago. Now all i need are the sockets! Thanks tech!
Old Oct 31, 2006 | 02:12 AM
nandrolone's Avatar
I had the same problem. Change he coils and plugs.
Old Nov 1, 2006 | 03:34 PM
ariston18's Avatar
I changed the ignition coils and spark plugs last night, the acceleration works like new now. Never knew it was this satisfying to do your own mechanical work!
Old Apr 5, 2018 | 07:33 AM
Shanvan's Avatar
Default S60
I have this misfiring on highway and in mountains too. I had all coils replaced, spark plugs were new when I got car but not Volvo brand. It now is still occasionally misfiring on highway. I pull codes on cylinder 1. Should I get Volvo spark plugs? I can’t keep dumping money into this old car
Old Apr 6, 2018 | 12:15 AM
pierremcalpine's Avatar
Get codes checked first.
Old Apr 6, 2018 | 04:16 AM
  #17
Hudini's Avatar
When you had the coils replaced did you also have the spark plug leads to cylinders 3 and 4 replaced? Each coil fires two cylinders.
Old Apr 6, 2018 | 10:20 AM
  #18
For what’s its worth I had a misfire issue that had me totally stumped on my 2004 S60. Turned out to be a dead upstream O2 sensor but I could not get any codes to spit out because I had an exhaust leak near the sensor. As soon as I fixed the leak, a bank 1 limit code popped up which prompted to change it out. Now purrs like a kitten.
Old Apr 25, 2019 | 11:28 PM
  #19
Bethuel's Avatar
Default Volvo s40 2.0
Mine was doing the same thing but now it doesn't want to start, what could be the problem?
Old Apr 26, 2019 | 06:23 AM
  #20
dead battery?
