Front door lock does not pop
My driver side front door lock does not pop open using the remote key. I can manually press it down to lock and open by using the interior lever for opening door.
Any suggestions will be appreciated |
I had this a while ago and the contacts needed cleaning inside the front door.
Some of the S40/V50's had an issue with the door wire harness connector corroding when it got wet and produced the same symptom. You may need to find the connector, clean it and put a little dielectric grease around the connector housing.
Stan |
Is dielectric grease really safe for the entire inside of the connectors?
Dielectric grease only displaces water. It does not conduct electricity. It's safe inside any connector.
| All times are GMT -5. The time now is 01:28 AM. |
