-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   Help with shock/strut (https://volvoforums.com/forum/volvo-s40-11/help-shock-strut-68840/)
FlyBoyd Feb 4, 2013 09:30 PM
I have a 2004 S40 and I have an issue with my right side shock. I replaced my shocks about two years ago and noticed there was a sound coming from the right one. I lifted the hood and when I bounced the car up and down I noticed that the top of the shock had movement. The left one was not moving at all. Would this be a failed shock mount? The sound it makes would make sense. Any idea how much that would cost. As I said I replaced the shocks just a couple years ago and have a hard time believing that they wont last 30,000 miles.
Any help would be great!
Thanks
yyk Feb 4, 2013 11:06 PM
I have the same type of noise in my '03 S40. It almost sounds like it's coming from inside the dash near the right side defogger area. I have already replaced the right side engine mount, so I'm inclined to think it's my strut or mount.
Hudini Feb 5, 2013 02:42 AM
1 Attachment(s)
It does sound like the strut mount and/or strut bearing. Here is an exploded view:
Attachment 17377
Hudini Feb 5, 2013 02:44 AM
You should start your own thread so as to not hijack the OP's thread. That way folks know who to answer without getting mixed up. :)
yyk Feb 5, 2013 12:40 PM
Thanks for the pics. We're just two newbies trying to help each other out; I'm not trying to hijack anything brother. Use the quick reply icon on the bottom right of the post you want to reply to.
GerBeGurGya Feb 5, 2013 09:41 PM
2004 Volvo S40 - 1.9L 4 Cyl (16 Valve) - Turbo Parts | Front Suspension | Free Shipping
rspi Feb 6, 2013 12:57 AM
OP it can be that the top bolt is loose. Did you try to tighten it or see if it was loose enough to loosen or tighten by hand? I found one loose the other day.
@ YYK; When you change the subject from the op's topic, that is considered high jacking a thread. That is what the NEW THREAD button is for. Hudini probably felt like you were changing the subject by talking about noises coming from the dash.
