horn not working
horn not working
Hi ive got a 98 s40 TDi which has been a great car but needs its annual MOT in a few weeks. Unfortunately the
horn has stopped working. Ive checked the threads here and the fuse in the car and theres no voltage at the horn connections. ive removed centre of the steering wheel which houses the airbag and horn connection plates. ive chekd the connection points are making clean contact. I also connected the two wires together to bypass the switch
which doesnt work either.... Does anybody know whether there connections that sit behind the steering wheel??
I can see the copper ring which sits behing the sterring wheel which i assume carries the voltage for the horn..
I took a voltage reading with one of the multi meter probes pressed on the copper ring thru wheel and the other
earthed and it only measured .5v which im sure is supposed to be 12v. Is there any wiring behind the ring ???
Thanks for any help..
Mike
Mike
RE: horn not working
ORIGINAL: mikeeyuk
also since reconnecting the airbag, the dashboard warning lights for thevairbag stays on..is there a method to reset it//
mike
mike
To remove the steering wheel, mark the wheel and the splined shaft w/ a white out marker or score it somehow so you can line them up exactly when you need to put them back on. be sure not to pinch any wires when re-installing the wheel assembly.
You can pull the covers off around the steering column to gain access to the Contact reel.(Copper ring)
Also check out the wiring diagram if you would like.
http://www.volvotechinfo.com/WD123/
