How to remove driver's side visor on 2005 S40?
I have had the dreaded sunroof blocked drain again on my S40 which I have cleared and the tube runs clear. However, in the process the connection from the drain hole in the roof to the internal tubing has come loose and I need to remove the ceiling trim to get access to reconnect it. Attached to the tubing that runs down the A pillar is a black plastic elbow fitting and another section of plastic tubing that must connect directly to the sunroof drain hole.
I have removed the handle in the ceiling at the drivers door, and I can see that there is one visible screw at the left of the visor but on the right hand side, where the swivel arm is attached, there seems to be a plastic cover over where another two screws are. I am reluctant to just force this cover off to prevent any cosmetic damage. I am looking for a pointer on how to remove this little cover so that I can remove the visor to gain access to reconnect the drain hose. Long story short!!! Thanks for any assistance. |
You just pry it off.
Originally Posted by ES6T
(Post 411542)
Write up: S40 (MY2005) Headliner Removal and Repair Thanks for your reply. |
Finally got it sorted and all put back together last night, thanks!
Sunroof Leaks - Part 2
OK - what part of a sunroof leak would dump water on ONLY the drivers side REAR carpet? Is there a particular drain tube which can be accessed from somewhere that would cause this? Front carpets are totally dry, so I am guessing the typical front pillar drain tubes are working correctly. Are there some rear tubes?
Hi, I think there are drain holes at each corner of the sunroof so that could be your answer! The rear holes drain down towards the rear of the car as far as I'm aware.
Did you see any REAR sunroof drain lines when you removed the headliner? If so, do you recall if the lines run down the B pillars? (Pillars between front and rear doors?)
Originally Posted by cincoblaze
(Post 411793)
