-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   Key stuck in ignition (https://volvoforums.com/forum/volvo-s40-11/key-stuck-ignition-2931/)
nandrolone Oct 2, 2005 03:51 AM
The button on the shifter does not pop out. Is this a common problem? Easy to fix?
tech Oct 2, 2005 12:50 PM
RE: Key stuck in ignition
If you look at the top of the button on the knob you will most likely see where it is broke.
It is pretty common.You will need a new knob.
nandrolone Oct 2, 2005 04:04 PM
How do you get it off? How much is it? Can you get it anywhere or only at volvo?
tech Oct 3, 2005 12:23 AM
I don't remember the price.I think you can only get it from the dealer.
The shift knob just pulls off.You will have to get the boot off the bottom of the knob first.You do that by twisting the lock ring in the boot and pushing down.
ZIGZAG Oct 3, 2005 01:55 PM
Mine happened too. I just have to push the button out manually if it sticks. Try a bit of spray lub might fix it.
