I own a 05 S40 and the key is stuck in the ignition and the car will not start....turn the key on and nothing happens....wont unlock the doors or anything...car is totally dead with key stuck in it....anyone no how to fix this?
While it's in park, make sure that the shift lock comes all the way back out. in my '00 it sticks so you need to push on the bottom of it a bit to get the top to kick out. then mine gives up the key.
Try stepping on the brake and wiggling the shifter while in park. Now try moving the key. It may be the shift solenoid inside the shifter that has gone bad.
