Sitting Idle Problem
Old 07-03-2010, 01:33 PM
Oni90's Avatar
Default Sitting Idle Problem
2000 Volvo S40
1.9L L4 PFI DOHC 16V
When I drive the car it's fine. But after I stop and put it in park. The sitting idle becomes a problem. The RPM begins to go over 1 and then back down to like 0.5 then back to 1.
It does this several times. Revs up and down. Anyone know what the problem could be? Replaced some bad hose lines, a new battery, spark plugs. But still doing this.
Any ideas?
Old 07-05-2010, 11:36 AM
SVTfocusO3's Avatar
The IAC, idle air control. Search this, you will find good info.
Old 07-05-2010, 05:46 PM
Oni90's Avatar
Someone told me in another topic it might be a bad MAF sensor.
But after reading up on IAC, I realized I already replaced some bad vacuum lines and it helped it a little bit.
The car runs fine otherwise, you really think I'll have to replace the valve? Cause just looked it up and it's gonna cost like $200.
Old 07-05-2010, 05:56 PM
SVTfocusO3's Avatar
You can take it out and try to clean it with carb cleaner.
Old 07-06-2010, 01:20 AM
stephenmcsmith's Avatar
Ye, I do agree. I also think that You can take it out and try to clean it with carb cleaner Or You can check your fuel pump relay.
PeterLeonard
02-25-2012 11:01 PM
onetwothreetim
10-17-2010 07:08 AM
bw77
08-15-2009 06:45 AM
dlk1
04-21-2007 06:46 AM
copycat923
01-27-2006 01:55 AM
Quick Reply: Sitting Idle Problem
