Mbc install
hey guys. installing a boost T. im going to run the same boost pressure as my tune but i heard installing a boost T helps with a more responsive turbo. Also i think my wastegate spring is a little weak so ill actually be able to hit the boost its supposed to. do i unplug the lines from the TCV that go to the compressor housing and the wastegate and put the Boost T in there? and leave the other line and the TCV plugged in? thanks!
