Motor mount help
Old Dec 26, 2012 | 02:06 PM
Shawnp204's Avatar
Default Motor mount help
Hello I have a 01 volvo s40 and I need some help!! First I need to know how many motor mounts and what the names of them are, and 2nd of all my car vibrates a lot and the transmission is a bit jerky and I think that's due to bad motor mounts... Please help thanks
Old Dec 27, 2012 | 06:11 AM
Hudini's Avatar
I've replaced all 4 on my 2001. There are 2 under the engine front and back. They are mounted on the metal bar that has the skid plate. That's the thing that hits the parking curb first when you pull in too far. Not that I would know that from experience. Ha. These are very easy to replace by removing the bolt between the mount and the engine then removing the metal bar with mounts still attached.
The main drivers side and pax side mounts are more expensive and a bit harder to remove. For the drivers side mount remove the battery and air cleaner box. Support the engine with a block of wood and jack under the oil pan. The mount is then easily removed once you jack up the engine slightly to relieve any weight on the mount.
The pax side is easily unbolted with a deep well socket as the studs are quite long. The one strange thing about the new pax side mount is that Volvo changed the design of the large aluminum support for the mount. And a new one is not cheap. I got around this by cutting a new groove in the old aluminum support to fit the new mount. This works but it does weaken the support to possible cracks from vibration. So far so good though. Ymmv
Old Dec 27, 2012 | 06:29 PM
GerBeGurGya's Avatar
Here you get everything
2001 Volvo S40 - 1.9L 4 Cyl (16 Valve) - Turbo Parts | Engine Mounts | Free Shipping
Old Dec 28, 2012 | 11:20 PM
Shawnp204's Avatar
Alright in your opinion what ones should I replace first. I wanted to do 2 at a time, but I can't afford to do them all at once. Like I said I have vibration and transmissions a little jerky
Old Dec 28, 2012 | 11:23 PM
Shawnp204's Avatar
Forgot to mention, when I apply gas or brake and turn I hear a clunk by the break pedal... Could that be due to bad motor mount?
Old Dec 30, 2012 | 06:40 PM
Hudini's Avatar
Sounds like all the classic signs of bad mounts. Mine would vibrate noticeably with the car in gear and your foot pressing the brake pedal.
You can always inspect the mounts before replacing them. The bottom 2 can be seen in place under the car. Look for cracks in the rubber. Mine was split all the way around. The top 2 can also be removed and inspected. On my 2005 the pax side mount was split completely into 2 pieces.
Shawnp204
Jan 23, 2013 07:39 AM
tuner4life
Apr 27, 2012 06:41 PM
duck4volvo
Oct 1, 2010 01:37 AM
phonostudio
May 2, 2005 08:59 PM
hispanic panic
Jan 14, 2005 07:59 PM
