-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   Motor mount help (https://volvoforums.com/forum/volvo-s40-11/motor-mount-help-67996/)
Shawnp204 Dec 26, 2012 02:06 PM
Motor mount help
Hello I have a 01 volvo s40 and I need some help!! First I need to know how many motor mounts and what the names of them are, and 2nd of all my car vibrates a lot and the transmission is a bit jerky and I think that's due to bad motor mounts... Please help thanks
Hudini Dec 27, 2012 06:11 AM
I've replaced all 4 on my 2001. There are 2 under the engine front and back. They are mounted on the metal bar that has the skid plate. That's the thing that hits the parking curb first when you pull in too far. Not that I would know that from experience. Ha. These are very easy to replace by removing the bolt between the mount and the engine then removing the metal bar with mounts still attached.
The main drivers side and pax side mounts are more expensive and a bit harder to remove. For the drivers side mount remove the battery and air cleaner box. Support the engine with a block of wood and jack under the oil pan. The mount is then easily removed once you jack up the engine slightly to relieve any weight on the mount.
The pax side is easily unbolted with a deep well socket as the studs are quite long. The one strange thing about the new pax side mount is that Volvo changed the design of the large aluminum support for the mount. And a new one is not cheap. I got around this by cutting a new groove in the old aluminum support to fit the new mount. This works but it does weaken the support to possible cracks from vibration. So far so good though. Ymmv
GerBeGurGya Dec 27, 2012 06:29 PM
Here you get everything
2001 Volvo S40 - 1.9L 4 Cyl (16 Valve) - Turbo Parts | Engine Mounts | Free Shipping
Shawnp204 Dec 28, 2012 11:20 PM
Alright in your opinion what ones should I replace first. I wanted to do 2 at a time, but I can't afford to do them all at once. Like I said I have vibration and transmissions a little jerky
Shawnp204 Dec 28, 2012 11:23 PM
Forgot to mention, when I apply gas or brake and turn I hear a clunk by the break pedal... Could that be due to bad motor mount?
Hudini Dec 30, 2012 06:40 PM
Sounds like all the classic signs of bad mounts. Mine would vibrate noticeably with the car in gear and your foot pressing the brake pedal.
You can always inspect the mounts before replacing them. The bottom 2 can be seen in place under the car. Look for cracks in the rubber. Mine was split all the way around. The top 2 can also be removed and inspected. On my 2005 the pax side mount was split completely into 2 pieces.
