Name of these parts
Name of these parts
I need to know the name of the plastic part that is placed next the the headlights in a 2002 Volvo s40. I know what the headlights are called (obviously), but what are the apparatus right next ot them. There are two and they usually operate when I switch on the turn signals.
Any help appreciated. Tnhankls in advance.
Respectfully,
Newport_j
Respectfully,
Newport_j
If the 2002 is the same as my 2000 S40, there's not much to show via a diagram. The CEM is located under the driver's side dash just above the hood release. its the box with 3 cables going into one side and there are two mounting screws. To remove the cables you need to push in the center tab and wiggle/pry to pull the connectors off.
As I recall, I had to remove the smaller cables first, then was able to spin slightly to get room to work off the larger connector.
