Non turbo block
check out the "Volvo Modular Engine" Wiki page to see all the variants of the motors. The NA motors run a higher compression ratio than turbo motors so while conversion is technically possible, it would not be advised as you'd be adding boost on top of high compression which would mess with the fuel mapping and cause pre-ignition on anything short of aviation gasl...
