Rear rotor allen head screw stripped
I'm in the middle of replacing my rear rotors. there appears to be a allen screw that needs removed to get the rotor off... I've stripped the screw even though there was half a can of PB blaster on it... any advice to get the screw off? Any advice on getting a new screw? do I really need a new screw? There was only one screw on it to begin with.
I used a 4mm allen wrench to go at it - think that was the right size - and it still stripped out. Any advise so I don't screw up the other side?
02 S40, 4 banger, turbo, FWD
Finally got the rotor off with enough pounding with my rubber mallet. Worked fine. The other side was easy once I figured out all of the tricks on the first side.... usually the case (I had changed the break pads a few years back and remembered I needed the break piston compressor thing for the rears.)
Just in case someone else ends up doing this job
I did find on the other side that the set screw was 4mm and I was able to get it off easily with some PB blaster and a quarter inch driver with a 4mm allen bit. DO NOT use a 5/32"... it's close - but not close enough - the metal on the screw is too soft for a 5/32". Also be sure to clean out the screw of debris before trying to get it off.
keaunym
03-07-2011 11:07 AM
