S40 AUX Input
OUt of curiousty, on the 2004.5 and up with Premium Audio, where is the AUX input located? Anyone have a picture of this, I want to do an install running video/audio/nav off a Nokia N800 and wondering how to set it up when I get my volvo
Thanks -todd |
aux input
it should be in your center console, covered by a flap of fabric maybe.
The S40's do not have any sort of aux input until 2007, I believe. I know my 2005 S40 does not and it's been an absolute nightmare trying to find a better solution than an FM transmitter.
I assume most of you have MP3 Players or iPods/Phones or something that stores music with a 3.5mm headphone jack. Also a tapedeck in your S40 like mine does.
If you got that, run to your local electronics store or maybe even some dollar stores.. get the tape deck that like goes into the tape deck and has a wire with a 3.5mm jack where you insert into your audio device. It works perfect, I have found that for most devices, usually around 60-75% volume level on the audio device is perfect sound quality. The rest of the volume just control with your indash audio controls. =] I'm currently using a Belkin one and it is AWESOME! |
i use this. connects direct through the antenna (spliter type jack) and has an external on off switch that you can mount where you would like, and then a headphone jack coming out of it.
works great. http://www.walmart.com/catalog/produ...uct_id=3661255 |
rCwuu--The 2004.5 and up doesn't have a tape deck--they switched to the slim center so I assume there wasn't room for one.
Tony--Do you have any idea where to install such a thing on the 2004.5 and up? I have an 05 and am trying to find anything other than an FM transmitter that doesn't cost tons/require extensive rewiring. |
well the actual silver box you can toss behind the radio just fine. and the switch can easy mount to any part of the dash, or an unused factory switch plug hole thingy. the power i just slaved off the radio (only makes sense...)
Originally Posted by PhragMunkee
(Post 169928)
Anyone try this?
Found this on ebay. Would give me what i want if it works. Anyone try this yet?
ETO Car Stereo for Volvo S40 Autoradio Navigation GPS Nav Headunit Bluetooth USB | eBay |
Originally Posted by GreasyTony
(Post 169231)
Swap console
Can I just swap out a 2005 console for a 2007 console with aux option?
