S40 egr?
Does a 2006 Volvo S400 2.4i have an exhaust gas recirculation valve?
I am trying to hunt down a what it appears to be an exhaust leak, that I can only hear on cold startup for about 30 sec. I have replaced everything from the engine block down.. Exhaust manifold and all gaskets, flex-pipe and cat, downstream O2 sensor, (did not replace the upstream O2 sensor) so I was wondering if this car has an EGR Valve.. Thanks |
here's something that may give you some ideas..
Do you see a small tube coming off the exhaust manifold? that's the EGR tube which should run up to the front of the engine to the EGR valve then into the intake... |
No there is no tube coming off the exhaust manifold. Here are some pictures from the original manifold https://cimg3.ibsrv.net/gimg/volvofo...b16d9f5bd.jpeg https://cimg5.ibsrv.net/gimg/volvofo...68904688d.jpeg I have many times checked and re-checked the gaskets. Last time I replaced them both with OEM (upper section facing the engine block, and lower facing the flex-pipe/cat) tourqued to the right spec. The video has a different system since the engine is not the same. |
