S40 - Reduced Engine Performance
For the past several months my 2007 Volvo S40 AWD has been experienceing "episodes" with a dash display of Reduced Engine Performance. These episodes reduce the accelerator response but allow me to continue to maintain highway speeds. I would not want to make any quick passing manuevers while this is happening as acceleration is sluggish. If I pull off the road and restart the car the problem is cleared. This does not trigger a check engine light. We went the route of changing the Turbo Boost Control with no change in the problem. Within the past moth we've finally discovered a pattern that is repeatable and consistent. With a full tank of gas the episodes disappear. As soon as we get below about 2/3 of a tank the episode happens on every commute (both ways). I would be interested to hear opinions on an approach to this problem.
Since you mention fuel then start with a fuel pressure check when it's acting right and then again when it's acting wrong. I've never experienced this problem so this is a WAG for sure. I'm thinking you would look for some difference between the two readings. If it's just a momentary trigger to the ECM that starts the reduced performance then you might not see any difference.
Same Reduced Engine Performance Issue
Hello,
I'm experiencing the exact same issue with my 07 S40 T5. I have not had the same experience with full/not full fuel tanks however. Were you able to fix your issue and if so can you please share what worked for you. Thank you for any assistance as this has already become a very expensive issue at this point... |
any other symptoms like longer than usual cranking when starting up first thing in the morning? the fuel system seems a reasonable area to be the first place to check out - pump, relay, pressure regulator etc. You can try swapping out the fuel pump relay - if that cures it then it may point to a fuel pump on its way out (there should be a way to measure its current draw - maybe its overheating...)
1 Attachment(s)
Well I finally experienced the message. It was the Fuel Pressure Sensor. 10 minute fix but not exactly cheap.
Attachment 14867 |
I have the same experience with my Volvo S60 T4 2011 model but has never focused on the fuel volume as such. If you got it right please share with me
Codes
Hi my 2010 Volvo S40 giving me the reduced engine performance message , when I press the mileage counter button its giving me codes 232 , 073 and 072 , anybody shed any light please , just bought this car and wasnt expecting this
Is it throwing any OBD codes?
Originally Posted by Paul Gibbons
(Post 490154)
Old thread
Originally Posted by BLM613
(Post 443331)
Hello,
I'm experiencing the exact same issue with my 07 S40 T5. I have not had the same experience with full/not full fuel tanks however. Were you able to fix your issue and if so can you please share what worked for you. Thank you for any assistance as this has already become a very expensive issue at this point... hey I know this was a long time ago but did u get it fixed, my car is having the same issue? |
| All times are GMT -5. The time now is 01:46 AM. |
