s40 right rear floor wet
Old Jan 9, 2011 | 09:53 AM
jimfarm56's Avatar
Default s40 right rear floor wet
Just bought a 2004 S40. noticed right rear floor is wet. Have read the TSB's on sunroof drain etc. Any other suggestions on what this might be?
Old Jan 9, 2011 | 01:01 PM
mkc70's Avatar
It always seems to be the sunroof drains.
Old Nov 5, 2016 | 03:51 AM
David Michael Karabelnikoff's Avatar
We've been noticing humidity in the car and wet floors on the passenger side. Even while it's not raining. Seems like the culprit is the AC Drain, I would love to see a diagram to know what I am looking for in cleaning out the drainage tubes, what if any tools are needed if removing the seat is nessassary or desirable . Shakey youtube video and libary memberships without the car repair manual promiced have left me wondering how I can find a good diagram of the system that seems to be troubling many folks. If I get some writen instructions I may try to make one but I could really just use the picture it's worth a thousand words.
1466
Old Nov 5, 2016 | 11:48 AM
Hudini's Avatar
There are usually 3 choices. Sunroof drains: there are 4, one at each A and C pillar. The front ones seem to be problematic. There are pictures here and at Swedespeed.
A/C drain: There is only one and the pax side foot well is a good indicator. However, it is November already. You still running the A/C?
My favorite: Heater core O-rings. These little beauties leak that stinky green fluid which flows to the back pax foot well and makes your feet sticky. This one is a PITA to fix. I spent hours bent over the door sill working in impossibly tight spaces. My ribs hurt for days after. If you are losing coolant and your interior fogs up continually, this is the place to look.
Old Mar 15, 2019 | 11:34 AM
quixote100's Avatar
The passenger side rear floor is wet (lot of water) and there is a slushy sound when the A/C is running. It seems to be a clogged A/C Drain, I wonder if somebody could recommend a fix to it. One additional question: where is the A/C drain located under the car? A picture or video could help a lot.
Thank you,
Old Mar 15, 2019 | 12:16 PM
habbyguy's Avatar
Might help to know what kind of car you have....
Old Mar 16, 2019 | 08:04 PM
Hudini's Avatar
If you have the 2004.5 and up S40 then remove all the plastic on the right side of the center console. Look for the rubber drain hose from the heater core area.
Old Dec 2, 2020 | 12:49 PM
volvo10's Avatar
I just noticed this thread and yep i got the same problem with my 2006 s40. How do you remove the plastic on the right side of the center console?
Thanks
bm97
Oct 23, 2018 11:03 PM
Gary Michael Appolonia
May 17, 2017 09:50 PM
LarryGM
May 5, 2014 07:32 AM
hermsen
Apr 16, 2011 08:07 AM
overheadcam
Mar 3, 2008 03:52 PM
