Some sort of main fuse..? Or something?
2002 S40.
Recent problem is that the heated seats, rear defrost, the map/overhead lights have all stopped working and the clock has stopped keeping time. It didn't work one night but everything worked again the next day but since have stopped working again. Also when I press the overhead light to the left the "open door" light on the dash lights up for some reason. Is there some sort of main fuse that controls all these things? |
Look at the fuse box lids for fuse locations for the seats etc.
It's clearly labeled. Martin |
You have two fuse boxes - under the hood and under the dash (near the hood release - the fuse puller is usually stored in the cover under the dash). After pulling the fuse you can probe for voltage etc with your multi-meter... You can also probe connectors - ie stick a paper clip into the back of a connector (where the wire goes in) without opening the connector. Look around for loose connections under the dash and under the seats as they sometimes can get kicked.
You can also look at the wiring diagrams for common junctions/connectors - intermittant problems problems typically point to connectors/weakened wiring (like in door or trunk jambs and sockets). From the owners manual: Fusebox, Passenger compartment No. Components Amperage 1 Blower motor, ECC -25A 2 Cigarette lighter, Accessories 20A 3 Accessories, Power windows, Power mirrors 10A 4 ECM for DSA/ABS/CEM. 10A 5 Seat heating 20A 6 Illumination of switches: Winter, DSA back-up lights, CEM, Turn indicators 15A 7 Cruise control, Shiftlock, SRS, Alarm 10A 8 Hazard warning flasher, Central doorlock activated, flasher 15A 9 Audio system, Cigarette lighter, Accessories 15A 10 Wiper/Washer front 20 11 SRS, ECM for DSA/Engine/Transmission, Combined instrument panel, Immobilizer 10A 12 Sun roof, heater/AC, Alarm, Seatbelt reminder 15A 13 OBD II connector, Brake lights 15A 14 Front wiper, headlamp wipers, Wiper/washer rear 20A Fusebox - Engine compartment No. Components Amperage 1 Supply to fuses 11/2-10 (certain models) 120 2 Supply to fuses 11/B 1,2,8 and 13 40 3 ........... ... 4 ........... ... 5 Rear window and side-mirror heaters 25 6 Driver's power seat 25 7 ........... ... 8* ECC, courtesy lights, ignition lock, Siren, Combined instrument panel 10 9* Central locking, alarm 20 10* Audio 15 11 ECM for immobilizer. engine relays 20 12 Power windows, Power mirrors 30 13 Radiator fan 30 14 Starter motor, supply to fuses 11/B 3-7, 9-12 and 14 40 15 ABS 50 16 Reserve -- 17 Fuel pump 15 18 Engine components 10 19 Foglights 20 20 Reserve -- 21 High beam L 15 22 High beam R 15 23 Parking lights 10 24 Parking lights 10 25 TCM 10 26 ........... ..... 27 Electric socket rear 15 28 Main light 15 29 Horn 15 30 Charger AC, fan AC 15 31 VAC pump (AT) 10 |
