Are T5 and 2.4i sparkplugs compatible?
Bought this one for my 2.4i 07 -
NGK What concerns me is that Amazon says it's not compatible with my s40 2.4i 2007, even though I've heard it is.(from here) And it says it's compatible with T5. Checked the gap, it's good. Checked the thread, it's good. Then is it compatible? Thus, can I ignore Amazon My car recommendation? |
The two engines use different spark plugs.
I used RockAuto and compared the two plugs recommended for the different engines and they are exactly the same size and heat range with a slight difference in spark plug gap. Although Iridium plugs are overkill for a normally aspirated car it won't hurt anything.
Center Electrode Core Material Copper Core Center Electrode Tip Material Iridium Gap Size 0.032 in Ground Electrode Quantity 1 Hex Size 5/8" Insulator Height ISO Manufacturer Heat Range 6 Additional Info 5K Ohm Seat Type Gasket Reach 26.5mm Thread Diameter 14 MM Ground Electrode Tip Design Standard Ground Configuration Standard Ground Electrode Core Material Nickel Core Alternate/OEM Part Number(s): ILFR6B Center Electrode Core Material Copper Core Center Electrode Tip Material Nickel Gap Size 0.024 in Ground Electrode Quantity 3 Hex Size 5/8" Insulator Height ISO Manufacturer Heat Range 6 Additional Info 5K Ohm Seat Type Gasket Reach 26.5mm Thread Diameter 14 MM Ground Electrode Tip Design Standard Ground Configuration Standard Ground Electrode Core Material Nickel Core Alternate/OEM Part Number(s): 4704, LFR6D |
Originally Posted by Hudini
(Post 445840)
You shouldn't notice anything. Iridium plugs with a smaller gap are used on turbo engines to prevent detonation and spark blowout. Neither issue is of concern for a non-turbo engine. Since the Iridium plug is more expensive it's even more reason not to use them. So did you find a screaming good deal you couldn't pass up?
I was just going off the Volvo part numbers. I don't know the differences but there is a difference.
(Post 445844)
