TPMS tire pressure warning
So I checked all the tires including the spare...all good. Now what Ive been reading is that these sensors need to be replaced after about 100k. Anyways I can get around buying new sensors?
Please advise and thanks for reading
If you aren't getting the Tire Pressure System Service Required light, you may just need to reset the sensors. With the car running, lower all tires to about 20 psi and then fill them to 36.
If that doesn't work, you may need a special tool.
I'm getting both the error message and the icon on the left, I'll try to lower the pressure and bring it back up. Also will look closer at the stems, replacing stems, is that easy...or expensive?
Thanks again everyone for the help and insight
