volvo s40
You are not placing an "add", you aren't even placing an ad. What you are doing is asking for help from people a whole lot of miles away so you have to give some basic info for us to have any clue what you have as far as a car, what you have as far as a car problem and what if anything you've tried to help yourself or had help with.
I'm not there so you need to give the cars information. Is it a manual or automatic ??
Hope you didn't do the alternator because of the no start as it has nothing to do with starting your car.
If you've tested the battery and it's good.
If you've replaced the starter with a know good one.
If the car will start if you push or pull it you should be looking at a bad ignition switch, bad PNP or neutral safety switch or blown fuse.
Have you tried to start it in "N", neutral ?? Have you tried to start it in all the gears one at a time just to see ??
Have you checked all the fuses ??
