-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   Volvo S40 stopped loading CDs (https://volvoforums.com/forum/volvo-s40-11/volvo-s40-stopped-loading-cds-111977/)
MarinosV Dec 18, 2022 07:16 AM
Hi all
I have a Volvo S40 since 2005 and I have a problem with the 6 CD stereo.
I had 4 cds loaded and when I chose to change the cd eg from 1 to 2, it ejected CD1 and wouldn't load it back. I changed into 2 and again it ejected it. Finally, I ejected all CDs and I can no longer insert a CD.
When I try, the CD enters and comes out with message Disc unreadable.
Anyone knows what's wrong with it?
https://cimg8.ibsrv.net/gimg/volvofo...8720b0023f.jpg
mt6127 Dec 18, 2022 03:09 PM
Are you using home burned CDs or store bought? If you burn your own, try burning a new CD using the slowest write speed with the overwrite option. Otherwise, buy a CD lens cleaner kit to see if that helps.
MarinosV Dec 18, 2022 10:31 PM
They were home burned but they were working for years without problems. I have tried an original yesterday but it had the same luck.
I don't think the lens cleaner will help because it will be ejected too in no time.
richardkonrad Dec 19, 2022 08:36 AM
Unfortunately CD,DVD and Blue Ray players all have a limited time , they are not used anymore as most cars outlast them , if you use it a lot then a CD player is good for 5-6 years and the rest 10 years max , laser pick up wears out, belts slip or break , motors break, etc
I tried to fix one once with a new laser pick up , it lasted 2 months then the same problem
MarinosV Dec 19, 2022 09:40 AM
Do you know which aftermarket player I can buy to replace it? I mostly want one with SD card and Bluetooth. I don't need the CD.
I have tried the FM transmitter option but it's horrible. Even if there is no interference the sound is not good.
mt6127 Dec 19, 2022 10:21 AM
Check out Crutchfield.com to see what they carry. Also, Grom makes an adaptor that uses the Volvo's CD changer port to add blue tooth and or a line in port (say you want to stream from your phone).
MarinosV Dec 19, 2022 11:43 AM
Thanks for the information.
I have checked both.
I have just found mr12volt has a device to add Bluetooth, USB, micro SD, microphone via the fiber optic of the CD player.
I need some confirmation from them and I will probably buy that device.
