Whistling sound
Old Oct 5, 2009 | 10:28 AM
StnThree's Avatar
Unhappy Whistling sound
Hi guys, I have this weird whistling sound coming from the front of the car when it’s under a load or when you goose the throttle … I just replaced the serpentine belts they need it and I thought they might be the problem. NOT… My next thought was maybe it’s an exhaust leak because I can smell exhaust under the hood. There is no leak from the turbo back I had a friend that works for a Monro test the system and he found nothing. I’m afraid that it’s coming from the turbo. Oh and i almost forgot the CEL came on yesterday. I haven't had the code pulled yet but i will.
Any suggestions???
As great as a new turbo sounds.... It's not at all in the budget.
Old Oct 5, 2009 | 10:57 AM
Somthngfrce's Avatar
I would pull the codes first since you have that and go from there! It will make it a little easier, since the car is sight unseen!
Old Oct 6, 2009 | 07:58 AM
StnThree's Avatar
OK and the codes are...
BB1
BB2
BB3
BB4
Old Oct 8, 2009 | 10:12 PM
AutoNaut's Avatar
There is a problem that crops up on the 2004.5 and up S40/V50 involving the crank case breather box and causes a nasty whistle/screech. Though as I recall, it is present at idle and goes away when you open the throttle.
For what you are describing, I'd check the vacuum lines.
Stan
Old Oct 8, 2009 | 10:30 PM
GerBeGurGya's Avatar
Not familiar with these codes but after some google I find ppl are talking about the EVAP system.I had a whistling noise once it was caused by a half way clogged up catalytic converter.It even sounded good but the CAT had to go anyway.
Old Oct 8, 2009 | 11:05 PM
AutoNaut's Avatar
That is probably the breather box. Volvo actually extended the warranty for that item.
Old Oct 9, 2009 | 12:42 AM
Well all I can say is the video was made with the CAT on then soon as it was removed the whistling was gone too.
Clogged CAT robbed a great deal of power too.Guess we dont know what kinda sound hes getting perhaps he could post a sample or something but the codes probably in there because of the EVAP so there is something to look around there..
http://www.youtube.com/watch?v=cFU0nqBz_8Y
Old Oct 9, 2009 | 09:18 AM
StnThree's Avatar
Well thanks Guys. I broke down and it is at the dealer now. I can't imagine that it would be the Cat because that was replaced when i go the down pipe back around March.
I just got the call from the dealer.... It's coming from the turbo. F***K!!
Old Oct 9, 2009 | 09:34 AM
AutoNaut's Avatar
Really! Do you have any warranty left?
Did they say that the problem is the turbo or could it be a leak in the intake plumbing?
Old Oct 9, 2009 | 09:40 AM
StnThree's Avatar
No they said it's coming from the turbo. It's still working but on the way out. I have an extended warranty but with the aftermarket stuff i have he has to check with his manager to see if they will cover it. Fingers crossed!!
If not I guess im in the market for a bigger turbo... Any suggestions?
Old Oct 9, 2009 | 09:59 AM
Dude, 19t,and a tune! Lol............... If it's the turbo, shop around because you know they are going to jack up the price...
Old Oct 9, 2009 | 11:05 PM
AutoNaut's Avatar
These cars have the turbo integrated into the exhaust manifold. I have only seen one upgrade turbo.
http://www.volvomotorsports.com/cata...roducts_id=147
It says it is for the C30 but it is the same engine.
Stan
Old Oct 12, 2009 | 09:49 AM
StnThree's Avatar
Man that would be nice!!! I'm gonna hope it's covered by the warranty though. I just don't have an extra 3K to put in the car at this point. My wife's Saturn Vue has to go!! That thing is the biggest P.O.S. I have ever owned. The CVT trans has been replaced three times now and its about to go again.
Old Oct 13, 2009 | 02:45 PM
StnThree's Avatar
Ok not covered... Big surprise!!
Old Oct 13, 2009 | 03:23 PM
SO what now??? If you're going to shell out the money, then UPGRADE TIME!!!
Old Oct 13, 2009 | 10:22 PM
AutoNaut's Avatar
What did they quote you for the repair?
Old Oct 14, 2009 | 09:53 AM
  #17
StnThree's Avatar
Yah I agree somethnfrce up grade would be nice!! They quoted $1900.00 that's still a lot less than an upgrade ($32..k parts alone) and I'm guessing I would need a new intercooler also.
I'm going to fight the good fight with the dealer and see if I can get anywhere. I'll keep you guys up to speed as I hear things.
Old Oct 14, 2009 | 10:46 AM
  #18
call corporate Volvo and get them involved...
Old Oct 14, 2009 | 11:06 AM
  #19
StnThree's Avatar
Yah that will be the next step. I talked with the service manager than I'll move to the dealer GM. They seam like they want to be helpful. **** they all complemented my car when I picked it up.
Old Oct 14, 2009 | 11:41 AM
  #20
Yes, but sometimes the compliments redirect your attitude onto something else.... I would just skip the GM and call Volvo. How far out of warranty are you? I forget what year your S is?
