Wipers and turning signals
RE: Wipers and turning signals
That's why I started thinking that there was some kind of relay controling both. Now, I tried removing the fuse for the wipers, this way my wipers would not work at all and after five minutesI can use my blinkers. Well,without the fuse obviously the wipers don't work but my blinkers never did either. I'm just concerned I have a 5 yr old girl and a 10 month little man and is starting to rain and is really dark outside while driving them around. I dissconected theCEM and tried to reset but nothing.How do I reset my computer ?maybe that will help.
I had the same problem with my S80 (wipers, turn signals, high beams, parking lights and controls on the steering wheel did not work) and this is what worked for me. This might sound crazy but, I'd look at the fuses for the turn signal and the high beams and replace them with new ones even if the ones that are in there are good.
Here read this... I know it is for an S80 but this might help you out because this is where I got this crazy idea. LOL
http://wiki.answers.com/Q/What_is_wr...e_is_not_blown
Well....Drum Roll... No cigar... Is all good. Back to square one.[:@]I stayed up until almost midnight working on the car, removed all the dashboard on the driver side took cluster out trying to follow the wiring and nothing... Any ideas what should I do next? Is a challenge now.
yeah just the bulb, do I go from the inside and unscrew it? Na those suckers are still doing whatever they want, but right now the fog is really bad and I need to replace those first. As long as I wait the 5 to 10 minutes before taking off I'll be ok, the problem is that I have to wait everytime I turn off the vehicle. But I'll get to those later.[X(]
#18
#19
