Wipers and turning signals
Old 12-12-2008 | 06:26 PM
Default RE: Wipers and turning signals
Also before I post them all what year is it to make sure I have all the proper info?
  #22
Old 12-12-2008 | 06:45 PM
I just went back reading from the start and saw it was a 2004 I hope it is the older body style?
  #23
Old 12-12-2008 | 06:51 PM
Ace Ventura's Avatar
Guess what amigo??Yeah !!!!!is the new body style, is that going to make a difference?[]Is the wiring different with the new body style?
  #24
Old 12-12-2008 | 07:05 PM
This is all I can get now the disc messed up again and I cannot see the legend.
I also had to rotate them so if it is really hard to see I will post it sideways as well.
  #25
Old 12-12-2008 | 07:06 PM
Yes it will be different ignore the ones I posted I will try to get the other ones and post them.
  #26
Old 12-12-2008 | 07:33 PM
Thanks, I honestly appreciate your help. have agreat weekend.[sm=hail.gif]
  #27
Old 12-12-2008 | 07:35 PM
Ok here we go again with the new info. Sorry its sideways but looks the best that way. They both run through the steering wheel module maybe that is where the problem is.
  #28
Old 12-12-2008 | 08:21 PM
BINGO!!!!!!!I have no control over anything on my steering wheel while this is happening...Can I replace that or do I need to go to the dealer for that? Your are a genius...
  #29
Old 12-12-2008 | 08:41 PM
You can replace it but the Dealer will need to download software to make it work.
So its your call you might just want to have them do it since they need to do the software anyways.
Could you atleast make out things on the diagram?
  #30
Old 12-16-2008 | 07:24 PM
AWESOME!!!!! Thank you. Just got back in town ( work stuff) The diagrams are perfect thank you, I 'm going to follow your advise and have the dealer deal with it. I'll keep you posted, now I 'm going to work with my fog lights ( no idea) Do I just buy them at any auto parts store?
  #31
Old 12-16-2008 | 07:27 PM
I would try to find an OEM set cheap and install them and when it is at the Dealer have them download the software to turn the function on.
  #32
Old 12-16-2008 | 08:40 PM
Thank you.
  #33
Old 12-16-2008 | 08:43 PM
Your welcome.
  #34
Old 12-17-2008 | 01:31 PM
News Flash!!!!!!!!!!Got in my, car turned on the carand BAM!!!!!Everything works find...I know....???????Well ,I got home and repeated what I did before I got into the car and it worked again...Here is the story and I'minterested in hearing what you think is going on. Everytime I start my car I press the brake pedal and start the car. This time it was so cold that I needed the heater to work right away, so instead of pressing the brake I stepped on the gas really hard like three times and then I saw the controls on my sterring wheel turn on and yes everything worked perfectly now at this time I'm thinking is just a miracle, But this is when it gets interesting, I tried the same thing this morning and guess what? YES it worked. Bad Battery ?
  #35
Old 12-17-2008 | 01:39 PM
Not sure maybe but I doubt a low battery would do that I would think it would show up when you cranked the car to start.
  #36
Old 12-17-2008 | 01:48 PM
That makes total sence. Well at this point I guess I just roll with it. Well I got the lights and guess what? they don't work at allI'm staring to think that I have a major electrical problem. I pulled on the highlights leverand nothing brother.[]Did you see my comment about me installing a new ( used) original CD player since it was missing when I got the car, Would this have anything to do with it?
  #37
Old 12-17-2008 | 03:49 PM
You mean the foglights?
No I didn't see that either. What was the car like stripped out when you got it?
  #38
Old 12-17-2008 | 06:01 PM
Ha, Ha, Ha... Na just missing the CD. the Wiper and signal deal started about a month ago.
  #39
Old 12-17-2008 | 06:17 PM
Oh ok you mean the car was messing up again!! LOL
If you put a different radio from another car yes it might be affecting it.
  #40
Old 12-17-2008 | 06:41 PM
I gotthe CDfrom a volvo recycler.
