Tire Inflation dash warning light S60
I recently have been getting a warning light indicating that my tire pressure needs attention. After checking all the tires and found 35 lbs in all four I figured it must be a faulty sensor. This light would come on and shut off periodically. Is there a sensor and where is it located or can I just remove a fuse to this annoying gremlin? Any help is much appreciated. Thanks, Fred
The following link indicates it should go out by itself and implies that you might try a recalibration.
http://www.fixya.com/cars/p691603-vo...23678/page-165
Adjusting (recalibrating) TPMS1TPMS can be adjusted, or recalibrated, in order to help adapt the system to different inflation pressures, for example when transporting heavy loads. To do so: - Switch off the engine. - Inflate the tires to the desired pressure. - Turn the ignition key to position I or II. - Turn the thumbwheel on the left steering wheel lever until the text TIRE PRESSURE CALIBRATION is displayed. - Press in and hold the Reset button until TIRE PRESSURE CALIBRATED is displayed. This completes the procedure. NOTE: TPMS should be recalibrated each time tire inflation pressure is changed.
derekmw
12-21-2012 11:43 AM
