03 S60 Squeaking right front when cold
Hello,
In the morning the right front section of my car makes loud squeaking and clanking noises as I go over slight bumps. After I drive a little while the sound eventually deadens so whatever the problem is seems to go away when something is warming up. What part of the suspension acts like that? Shocks? Struts? Actually, even when the loud noise goes away I still feel a little knock now and then so something isn't right.. What should I tell a mechanic to look for? By the way, 107K miles.
Thanks.
Thanks.
The right spring seat on my newly acquired 2004 was also making noise, when cold. Part was $25 on line, took me about an hour to replace. You will need a spring compressor, and an impact wrench helps. I bought a seat for the left side, but haven't replaced it yet, since the original appears to be OK.
Steve
Steve
Wrowley11
07-26-2012 09:52 PM
