'05 s60 rubbing noise on tight turns
I've noticed a rubbing noise when I make tight slow turns (say when turning around). I seems to be like the tire rubbing against plastic. Too cold out now or I would do further debugging. Any ideas?
Hi, I'm resurrecting this old thread.
Both front tires on my 2006 s60 rub on the wheelwells at full turn. The left tire rubs when turning full right, and the right tire rubs when turning full left, so it's the leading inside edge of the tire that rubs on the front inside of the wheelwells.
I've been reading about steering limiters, and will look at that first, but I remember seeing there is the possibility of something worse going on.
Fingers crossed it's a simple fix of swapping the steering stops from each side....
Iggyomega
Apr 10, 2020 07:23 AM
Nightc
Jun 1, 2015 12:51 AM
