2001 S60 POWER STEERING QUESTIONS
Hi Everyone The mechanic saidthe power steering pump is bad but when I look at the hose coming off the top it is wet at the connection. The clamp is not a screw clamp If it was the pump leaking is it possible for it to show up on top at the connection? Does anyone have a illustrations? Any suggestions on whether maybe something could be loose and just needs to be tightened. It is not making any noise at all butI did have to top off the fluid with 1 pint.All help is appreciated. Thanks
RE: 2001 S60 POWER STEERING QUESTIONS
Replace the clamp and you should be fine.
