What size hose for ATF flush?
I have decided to do a flush and I couldn't remember the exact size of hose I needed to drain from the radiator connection (green clip). Do I need a 1/2" diameter hose or this the wrong size? I read in some other posts that some people even used a garden/water hose and it worked fine. Any suggestions? I need to pick up a hose today so I can do the flush tomorrow.
Thanks!
Thanks!
RE: What size hose for ATF flush?
nsc60
I'm planning to do a transmission flush too on my 2000 s80 at 90k mile. Could you send a step-by-step of how you do yours? This is my first time. Normally just drain off from the oil pan and change filter which is only partial replacement of the old oil.
Thank you for yur time.
