2002 Volvo S60 2.4 Timing belt question
Hi, Im trying to change the timing belt on my moms S60. I printed out the Vadis manual for replacing timing belt. I can not get the top two gears (i guess those are camshafts) to line up with markings on the top plastic cover. I propably did 5 miles worth of rotations in attempt to achieve what is on the picture of the manual. Do I line up the "M" marks with the markings on the top cover?
Thank you |
There should be little lines that match up with the cover. If not then like up the crank mark then make your own marks on the cam pulleys and remove the belt and install the new one.
Great, thank you! One more question, the lines are very small right?
Yes they are.
Thank you so much!
Your welcome anytime.
Damn, i havnt hear " VADIS" in like 3 years.
